I am replacing the shift cable on my Alpha 1 drive and its the newer style so that you need the special tool (elongated 9/16" socket) to remove the sleeve from the bell housing. Well the brass fitting that the outer cable sheath goes through is not comming off and I now rounded over the edges of the nut. I then cut the nylon inner piece off so I could try shorter sockets to try and grab it but no luck. I don't want to use a torch or anything since the bell housing is aluminum and the nut is brass. I am afraid of melting or distorting the bell housing. Does anyone have experience in removing this fitting like this and how would you do it? I would hate to spend $300 on a new housing just because the fitting is frozen in place.<br /><br />Thanks for your help,<br />Bob W.
