Re: 1987 Mercruiser 5.7 dry joint conversion
FYI - This isn't a live chat room, it's a bulletin board style forum. It's great when answers appear within hours, but it often takes longer than that. For example, I just read these posts at lunch each day.
I would also be interested if there is a cookbook solution for this. As near as I can tell though, the risers have to change and the thermostat housing has to change. Most likely there are other parts that will change such as the boots and ells between the risers and the Y pipe. Don't know for sure though. Did you do a search on the forum? Seems to me someone was discussing problems with their dry joint system and there may have been information in that thread you could use.
John
