Model- 1989 Johnson 100gt j100stlcem
Needing some help with my tilt and trim motor on my Johnson outboard. So here is the deal. One day I was tilting the motor up to put the lock down. i got the motor all the way up, put the lock down and hit the tilt and trim switch to go down and nothing. Hit the switch to go up and nothing. The up and down relays are clicking and sending volts down to the lift motor but the motor isn't moving the hydraulics up or down. So i thought I would cover all the bases and buy 2 new relays and a new 2 wire tilt and trim motor. Installed the new lift motor and relays. Now that I have a new lift motor at least it responds in the down position, but will only click when you hit the up position button. Here is the interesting part to me, when I switch the blue wire and green wire around to the connector coming from the outboard, as long as I hit the down trim button, i will tell it to go up, if I switch the wire back, and I hit the down tilt button it will tell it to go down. I'm lost on the next stage to get my tilt and trim working correctly again. If I need to give any more information please let me know From one boater to another, can someone please help me solve this problem?
