I saw someone ask about this the other day but never really saw an answer, sorry if it was.
When doing the spark gap test I set the tester to 7/16" and verified that the spark jumped the gap on all 4
cylinders. Is it important what color it was or is it just making sure that the spark can jump the gap?
The color of the spark while jumping was a lite blue. Is this sufficient? Motor is a 87 Johnson 88HP SPL(J88MSLCUS).
I've been fighting a no power problem under load. Following has been done:
2 new powerpacks( 1 of them was bad so I decided to do both)
4 new coils
New Plugs and wires and gas. Compression is 140 pounds on all four cylinders.
Temps on all 4 cylinders seem ok. Water pump was rebuilt earlier.
I have the 2 carbs torn apart now. I don't see any real varnish or plugged orifices, so I'm not sure this is the problem.
Going to rebuild them anyways so that I know what I have. Plan to rebuild the fuel pump also since the carbs are off.
Does anyone have any other ideas on what to look for if rebuilding the carbs doesn't help? I doubt I will be
able to get the boat back in the water this year. Was thinking I could check out other possible causes over the winter.
Thanks in advance
Jerry
4 new coils
Thanks in advance
Jerry
