Re: 6hp johnson restrictor plate ????
Hi slate123. That would be nice if your Father-in-Law was still at Cosworth. You could have a one of a kind Cosi outboard. Unlike cars, generally speaking, outboards can't really be "tuned up" much beyond their factory specs, for a variety of reasons, particularly vintage models. To make matters worse, the timing on these motors is fixed and set by proper placement of the flywheel :/ As a result, I'm not sure you can increase it, so any extra fuel/air you might be able to get into they cylinders by opening up the restricter plate would either be wasted, or possibly even hinder the motor's performance by creating an overly rich mix. The only thing I can think of is to figure out some way to get the armature plate beneath the flywheel to rotate a few more degrees, but I'm not sure how to do it. Of course, all of this assumes that the engine block could handle the increased stresses, such as they are, which is again any area of uncertainty.
