About a month ago I bought a 1983 Trophy 2460 model with a 305/280. The boat lists about 4 to 5 inches to the starboard side? with no one on it. I?ve checked every compartment and there are no signs of water. I?ve even empted the fresh water tank, the fuel is in the center. There are no hull cracks or holes. I?ve been told that it?s a manufacture weight distribution flaw, I was told when these boats were made they didn?t use a CAD system for weight and balance. In short, the weight of material is greater on the starboard side vs the port side. Because of this problem the trim tabs don?t work right when underway. Does anyone have any input or background on this type of problem. I understand the only easy fix is to add lead weights to the rear port side.
