98 40hp Mercury Force broken screw assembly on carb
taxlady
I had a leak at the screw assembly on the bottom of the carb bowl. The nut kept coming loose and allowing rough running and fuel leak. When I went to tighten the nut, it broke the nipple off that holds the drain line. It appears to be a really hard part to find. Are there any alteratives I could implement, maybe using another part not specifically designed for this particular outboard. Need to get back on the water ASAP, crappie are waiting for me....Thanks
