I have an aq130 with a 270 outdrive. I just got the boat and have been trying to get it going. I have it running right now, but cant get it to run on ear muffs. I have been running it with the hose on the inlet side of the pump inside the boat in a bucket. It sucks water fine and keeps the engine cool, right around 180. However when I shut the engine down the temp gauge goes up to around 240. Is this normal? Also the engine block and head are very hot, however, the exhaust manifold is cool to the touch. Also when I went to drain the block peck **** only a few drops of water came out. Is there a chance that the water passageway is blocked?
One last thing I noticed is the exhaust manifold is cracked around one of the freeze plugs. Can that be welded? There is only water dripping out of it.
