Im having trouble trouble shooting my outboard problem rough idle and delayed acceleration , rebuilt cylinder heads , replaced all below deck and above fuel hoses , new racor filter , new screen filter , rebuilt carbs , rebuilt vapor seporator float bowl , checked coil packs and cleaned all points , holding great fuel pressure if i push throttle all the way down it bogs the only way to jump on plain is slowly while holding the key in choking it once im up and running its great note Vro is capped i mix 50:1 and if i hold 2 fingers over the top starboard carb troat it idles higher
