Hi all,does anyone know how many turns out the low speed adj.screw is?The original one got bent somehow and I replaced it with a new one.I ask because it's most of the time a pain to start.It seems to run good too with the choke half out so maybe it needs more fuel or would the jets be getting plugged?Where can I find a manual that tells how to remove the carb?The motor says 100/1 on the lid...is that safe?How hard is it to remove the all the stuff just to get to the carb?Also by accident I started it by leaving it in gear and taking off with the main motor.Rode around for awhile,about 25mph and when I stopped the boat it was running.Could that have hurt the motor by spinning the prop too fast?Any replys greatly appreciated.:facepalm:
