Nutron
- Jul 10, 2011
- 73
Just a quick question. When I put the motor in gear I can hear a clunk! I was working on it in the garage and putting it in and out of gear I can hear the clunk, it's not overly loud but when I put in the water I can't hear it, is it normal or is there a problem. The other thing is I did drain the lower gear oil out and put the plugs in, I was told to drain and leave empty until the spring again. Is this also correct? Anyway I thought maybe the sound was due to no oil? And no I did not have it running at the time, I understand it is bad to run with not oil. Thanks for the help.
