Hi All! I'm stumped. I had to replace my trim switch which meant taking apart the remote control box. That part was easy as well as reassembly....Everything was going fine until it came time for me to put the last of it together which includes the cover that has the neutral throttle lever. I can't seem to figure out how to make it fit. I have tried many different ways but I run into a couple problems, 1st try: neutral throttle lever went through full range of motion but the control lever did not go all the way forward, 2nd try: control lever went all the way forward but not reverse and neutral throttle lever would not move. Here is a picture. Any help is appreciated! Thanks!
