Drain Plugs
1stgenbird
What's the general consensus on the installation of the drain plug, from the inside or the outside? Until this year, I have always had 12-14ft tinnys and put the plug in from the inside. This year with a 19' I/O, I still install a rubber screw type (not the lever type) from the inside but it's a pain removing the rear seat and reaching down into the bilge to install it. I have seen a few of boats with the plug on the outside but I would think it would be more apt to fall out.
etracer68
Ensign
Re: Drain Plugs
I personally prefur a brass pipe plug type, that screws in from the outside, but you always have to carry a tool for install, and removal. I dont like the lever type at all, but the T handle ones are ok to use on the outside, just make sure its in straight, and tight.
1stgenbird
Re: Drain Plugs
Thanks. Even though I searched on this topic prior to posting, I subsequently found other threads on this topic. Outside is ok but stay away from the using the lever types outside.
JEBar
Re: Drain Plugs
unless I'm in a boat without a floor blocking access to the plug, I agree with the above .... I've owned a couple of tiller steer aluminum boats where I used a lever type plug inserted from inside boat .... that made it very easy to pull the plug while underway to drain some water out of the boat
Jim
Georgesalmon
Re: Drain Plugs
Been putting the plug in from the outside for over 30 years, no problems. Lever type, I always make sure the lever is up or to the side above the bottom of the hull.
Quit It
Re: Drain Plugs
I like the Beckson because of the retention feature and the lever because they're tool free. Anyone installed a lever with a tether?
WIMUSKY
Re: Drain Plugs
I have one of these on my boat:
http://www.jamestowndistributors.co...ct.do?pid=10292&familyName=Beckson+Drain+Plug
I really like it because it's easy to put in and take out and you always know where it is and never have to worry about losing it.
I have a similar screw in type. As mentioned, it's always there.
Previous boat had this style. Never an issue.
I've always plugged from the outside....... I see it as personal preference......
MH Hawker
Re: Drain Plugs
I have always use the T type from the out side, snickers back when my boat needed a plug.
Yacht Dr.
Re: Drain Plugs
Outside screw drain is the way to go. Its not apt to fall out. Its actually a pain to unscrew it you over tighten it. .. or tighten it too tight ( they are pipe threads ).
YD.
lexer440
Re: Drain Plugs
I too prefer the outside one, mine is slightly tapered and fits very snugly without needing to be super tight. My last boat had an outside one too that also had a ping pong ball in the drain tube, it rolled back to let water out but if you forgot to put the plug in, (who could even do such a thing:facepalm:??), pressure would push it to close opening, not a 100% seal but easily down to where bilge pumps could cope.
jsimms724
Re: Drain Plugs
Me too , I like being able to see the plug.
Home Cookin'
Re: Drain Plugs
if you put a lever type outside, I'd also tie to the boat. Of course, you also have a spare in the tool kit or glove box.
My preferences (plural b/c it all depends on the boat):
---use a rubber plug inside the boat for a boat you would run the water out.
---Use a metal screw-in (garboard) for a boat that you don't.
---Don't rely on a floating ping pong ball to keep your boat floating
---A rubber plug outside has more chance of falling out and being lost than a rubber plug inside, so why take chances?
