comcastic
- Sep 22, 2011
- 15
i just recently bought a 1963 boston whaler 17ft with 1977 70hp johnson seahorse... on my second time out with the boat i had it at wot when i got out of the marina and after about 70 yards the engine sputters down and feel like the boat is running at idle even though i have the throttle all the way open...after a few seconds the engine stalls...i restart the engine and it throttles up fine in nuetral...when i out it in gear and accelerate slowly the engine does not respond...when i put it back in neatral and rev up the engine....the engine throttles up fine....when i check the primer bulb it feels soft so i pump it firm and the motor runs fine again...but after another run the engine does the same thing..i have to pump the primer buld again.... my whaler has the gas tank located about 8 feet before the fuel filter/serperater, then another 2 feet of fuel line and the primer bulb before the engine.... i'm planning on ordering another filter for the separater...the filter on there is a sierra 18-7945... my gas tank also has the vent hose and it was open during all of this...do you guys think it could me the fuel pump too?... when the primer bulb is firm it seems like the engine runs fine...topping off at about 30mph.
