I have a 1977 Bayliner with a Merc 140 hp that I have owned for 25 years. After years of taking it to a mechanic I decided to dive in and try to work on it myself(limited mechanical skills but a helpful neighbor) Recently I replaced the head(rusted through), cam(likely victim of a hydro lock), water circ pump, sea water pump and base(just old), etc.
Got it into the lake last weekend for a sea trial. Started great, stayed at 140 degrees, idled smoothly but hesitated upon acceleration. If I gradually eased it up it ran great on plane.
I just changed the canister fuel filter and it was water free. I was thinking my next step would be to change the fuel pump filter and carb filter and also hit it with carb cleaner and some seafoam in the tank.
Any other suggestions before I resort to rebuilding the carb.
I just tried to check what type of carb it is and I believe it is a Rochester, hard to read with a flash light.
Thanks as always for any advice you can offer.
Greg
Greg
