Re: Dual trolling motor
LOL.
- Does it really matter if it's a 20ft pontoon or a 24?
- He wasn't asking about any other means of propulsion so why be concerned with anything else but the trolling motors.
- Distance doesn't matter
- Speeds-kind of what he's asking in other words.
- How it is steered is no concern. He wasn't asking about how to steer it.
- Inverter does not matter. He said batteries are not an issue- so moving on
- 36volt motors will not consume a large amount more than a large LB thrust 24volt motor-In fact you will have a net-much longer battery life
- Again battery life isn't a concern of his.
1) Just like a V-hull, it does matter if the pontoon is a 20 or 24 footer -- especially since we had no idea what other forms of propulsion there were being considered.
2) Yes -- he wasn't asking about other forms of propulsion. But when advice is asked for, why not ask for all of the details so a reasonable response can be provided. Do you just tell your doctor I don't feel well and let him figure out why? Or do you provide additional details so he/she doesn't have to pry the info from you.
3) Distance does matter if one does not know if there are other forms of propulsion, especially since using an inverter to charge three batteries (or six of them) might be an issue due to output current capacity.
4) "Beneficial Thrust" is sort of a meaningless term lacking other meaningful information.
5) How it is steered is of no concern to me since it is not my boat but when one invests time and effort into a project at least weigh the variables. Fact is, a bow mount troller on a pontoon is far more effective in wind and current than a stern mount. If you've ever been solo in a canoe and had to fight a cross wind you learn in a hurry where the best position in the canoe is. (hint -- it is not the back!) Where the motors would be mounted were not indicated.
6) See #3
7) `101# 36 volt Minnkotas draw a maximum of 46 amps each. Two of them at 1/2 speed is about 46 amps. Is the inverter on this vessel capable of dumping a MINIMUM of 46 amps back into the battery bank (23 amps each into two banks or 46 amps into one) just to maintain battery level?
8) Maybe battery run time isn't a concern of his --- But should it be?
Have you ever been asked a question and when you answer it, determine that you look rather foolish because your answer was based on too little information? Sure -- it's easy to say "but you didn't tell me that" . So why not ask questions to avoid that situation and to help avoid long drawn out posts where more time is spent extracting information than solving the problem. Besides, if the poster had all the answers he/she would not be asking for help would they!
