overkillthemighty
- Jul 6, 2012
- 13
I have posted two other posts about this engine here in which I decided to repair the engine. I ended up only needing to replace the rings, and I have just finished. I got the engime back together and mounted on the boat, but I cant quite get it to start. It seems like just as it is kicking in the starter cuts before it actually starts, but I am not sure. The timing belt was a bit of a chore, as there was no mark to indicate tdc to align the distributor, but I pulled the plug on #1 and got the piston to tdc as best as I could and slipped the belt on with the arrow on the distributor cog pointimg toward the crankshaft (as per the service manual). I looked at the position of the distributor vs the position of the piston and it looked right. I hooked it up and after taking care of a couple of snags (a split fuel line and a dead battery) and doubling the oil in the fuel I tried to start it. The videos are what I got. Anyone have any ideas?
Video 1: http://youtu.be/JVRKxbnhr6M
Video 2: http://youtu.be/yuUztzex-54
Here is my previous post BTW: http://forums.iboats.com/showthread.php?t=574554
Here is a picture album of my work so far with the boat: https://plus.google.com/photos/100505445322883170247/albums/5745379227576870641
