Can't get Lower unit to drop on 1965 Johnson Seahorse 6hp
johnuwmad34
Help! Need to change the impeller on a 1965 Johnson Seahorse 6hp (CD-22M). I'm undone the 4 bolts, and undone the shift connecter and I can't get the lower unit to come off. Is there another connection I need to undo? Thanks!
tx1961whaler
Re: Can't get Lower unit to drop on 1965 Johnson Seahorse 6hp
Rotate the flywheel. There is a slot up there that has to line up with a pin on the driveshaft before it will completely fall down...
boobie
Edit....
