one side of engine block not draining
tim39
volvo 4.3 osi, 2003: While attempting to drain both sides of the engine block, the starboard side drained out about a pint of water and the port side is only dripping out. I've attempt to use a small probe to clean out the plug, but it is still only dripping.
Are there any other ideas how to unclog the hole?
thanks............
Alwhite00
Master Chief Petty Officer
Re: one side of engine block not draining
I had the port side that would not drain and gave it a blast of air with the air hose and it ran like a river then, Worked good.
LK
Don S
If it's a drain fitting, remove all of it and clean out just the block, just not the tiny hole in the drain fitting.
Ayuh,... Welcome Aboard Tim,... 'n prod 'n poke it clean with a #10 screw,...
the threads help yank the crud out.....
