cheburashka
- May 28, 2005
- 715
My mercury 140 (pre-alpha outdrive) was stalling at any speed above idle. I replaced the fuel lines and filters (which weren't letting much fuel through)and I'm about to put it back in the water but something occurred to me--if I override the gear selector and start it in neutral, it won't start running unless the throttle is set very low. If I try to rev it in neutral it just dies. Is there some kind of interface that keeps it from firing in neutral if the throttle is set too high? A mercury switch or something else that grounds it out? Is it possible that this interface is somehow kicking in when the engine is in gear? <br /><br />Thanks as always<br /><br />Steve<br />1971 Glasply
