chconger
- Jul 3, 2012
- 315
Hi All
I have a 1990 Glastron SSV199. I am replacing some of the decking, and flotation foam on the port side, about 1/2 back to the stern. Did the starboard side last year.
Stringers, engine-mounts are fine. Yay. (Edit; no they were not - did not understand what I was doing at the time)
But I see there is some rot in the transom around an eye pad that was bedded poorly and leaked. Looks to be a soft area about 1 foot diameter, probably 1/2 inch deep.
The transom is fine around the cutout for the stern-drive, its fine everywhere else. The problem appears to be localized. Although I have to do more exploring on the weekend.
So.... I would rather not replace the entire transom for a limited problem. But I also dont like doing things twice. Is there a tipping point where one says; it hast to come out?
Secondly -- assuming I do so, is there any advice on partially replacing or repairing limited rot in a transom?
Thanks Much
Chris
Thanks Much
Chris
