Damn, did not have time to check boat during 2 weeks and it had "sunk" enough so that there was water in the lower cylinder, over the wiring harness connector, key switch, solenoid, and starter connections. Well, turned the engine by hand, applied CRC all over and inside.
Cleaned the connections at solenoid which was the only place with more corrosion. Confirmed later that battery had still power, either the electric choke or starter did not operate however. I did not have tools to check electrics, but I would have get the outboard running again and will have to order parts before I can check them. Coils, CDI and flywheel were not under water. Any experience how likely I'll need a new starter, solenoid, and/or key switch?
