I'm in the process of replacing the Merc 4.3L engine out of a 1994 19' Sea Ray. The previous owner did not winterize properly, and you guessed it... a cracked block. I found a truck engine that seemed to be in good condition, and have swapped everything needed from the original engine. I installed new felpro head and intake gaskets, brass frost plugs, and had the engine running on a skid for about 45 minutes. All was really good, until I checked the fresh oil I put in it, and it was slightly milky... I pressure tested the cooling system with 12 -14 PSI, and I can hear a very slight hissing air sound coming from the spark plug hole on cylinder #3.
I did not use any sealer on the head gaskets, as I believe they are ment to go on dry. The surfaces were well cleaned before it was assembled. I then pulled the head back off, and checked to make sure the surfaces are flat with a straight edge, and they seem to be good.
Is there any type of sealer I can apply to the gasket to fix this small leak?
Thanks for your help!
