Boat set up for Mercury or Johnson/Evinrude?
bart98stang
Hey fellas
Could someone smarter than me regarding boats please answer my question. I just acquired a '92 Sunbird SPL 194 complete in pretty good shape except for carpet and no outboard. They person I bought it from stated that it was set up for a Mercury, however, it has OMC controls. I did a little research and if I'm correct OMC outboard controls are for Johnson/Evinrude outboards? Thank you very much
82rude
Re: Boat set up for Mercury or Johnson/Evinrude?
that is a j/e control alright.send a pic of the other end of the controls thats the only thing id be worried about is if the last owner made up some sort of frankenstine rig.
bart98stang
Here you go, thank you sir!
82rude
maybe somebody familar with elect plugs can chime in i was more curious about the actual shift and throttle cables.what do you want to put on the boat anyways? id certianly not let whatever you have now stop you from getting what you want .get a motor with controls and cables included in the deal.the elect cable has nothing really to do with that shifter as if i see corectly in the pic your key is dashmounted?lets see the cable ends .hopefully somebody will see and send you on the right track if im not around ,lots of smart cookies here.
bart98stang
I'm sorry, here is the pic of the throttle and shift cable. I want to use whatever the boat is set up for. If it's set up for Johnson/Evinrude than I will buy a J/E outboard and same it it's set up for a Mercury. K.I.S.S. Keep It Simple Stupid is what I always say. yest the key is dash mounted. Thanks again.
82rude
they look just like my j/e cables.what size motor was on there ?still if you decide to stay with j/e get the controls also if you can that way if you run into any issues you have a known good part.
bart98stang
I really appreciate your help!! I'm not sure what was the last motor on there, the guy that I got it from never had a motor on it either and he told me it was set up for a Mercury. Thanks again!
