350 Mag Y-pipe
qws
I have a 93 crownline with the 350 Mag 5.7
I've been thinking this winter while its put up I'm going to be putting in thru hull exhaust. At this point I'm not going with a divertor but only the tips with silencer. My question is there someplace I can purchase plugs or a maybe use a furnco type cap with hose clamps on the y-pipes. I'd prefer something thats fairly easy to install and I'd like to keep it so if I do put the divertor in I can just easily install it.
thanks
nikon
Re: 350 Mag Y-pipe
I tried this same thing, everything I tried leaked. This includes 5200 around the back flow valve...only thing that worked for me was pulling the y-pipe and installing a block of plate. This does of course require removing the motor.
qws
Re: 350 Mag Y-pipe
thanks for the reply. Actually I think I got kinda lucky today. I found a complete setup ...used sound advantage by IMCO, everything minus the actual tips for $350.
nikon
Re: 350 Mag Y-pipe
Ya, that's a damn good deal...wish I could have found something that cheap when I did mine. Thru hull sounds great, but it does get a little annoying after a while.
Re: 350 Mag Y-pipe
Ayuh,.... I've regretted it since 'bout a week after I did it.... Years ago..... Many years ago.... :facepalm:
