oldschooltiller
- May 4, 2012
- 67
First I'll probably add a couple to these as I think of them. But I do have a couple now.
1st: Has anyone had exposed pedestal bases powdercoated?
Concerns. All pedestals are the wedge/taper lock series. So I don't want the inside of the base getting covered in paint. Also I'm concerned about the aluminum being weakened during the heating process when being powdercoated.
2nd: If using 3/4" ply for decks, would it be OK to use a router to route out the underside of lids so that the carpet can wrap around it, and no increase the lids "thickness"
Only concern here is that I create a weak spot on the edges of each lid. Maybe the reduced thickness won't matter if starting with 3/4"?
