FredMercury
- Oct 14, 2012
- 4
I despair! I've narrowed the (non) starting problem down to the carb as it starts readily if fuel is poured into plug holes. I've now removed the carb 3 times, and each time removed anything removable, cleaned and then blasted air through every available orifice. The diaphragm is definitely working as I got a facefull when I pressed the button!
My questions are:
Where exactly is the idle jet located?
How does one remove the vertical brass jet/tube thingies that sit vertically in the carb throat?
Thanks in advance.
My questions are:
Thanks in advance.
