I know this might be a dumb question but what holds the wires to the lower motor cover assy.? I've attached a guide wire to the shift wires & I have the lower unit lowered 1/4". The manual says to just lower the unit & pull the wires through. My guess is that there is a rubber grommet attached to the wires which has to be pulled back in place on re-assembly. Is this correct?
