Yamaha Outboard 2 stroke engine maintenance
Marques
I have a Yamaha 2 stroke engine from 1983 which have the serial number 60CF 6FO 304339, and I need parts for the engine to maintenance, I already tried on the internet but with no success. If somebody could help I would appreciate
Thank You
Bamaman1
Re: Yamaha Outboard 2 stroke engine maintenance
You can Google "Yamaha outboard parts" or go on IBoats.net and click on outboard parts. Sounds as if you're not very sure about the history of this 60 hp 2 stroke. On any used motor, I would do the following:
Change the water pump impeller.
Drain the lower unit looking for milky grease or water.
Have the lower unit pressure and vacuum checked by an experienced marine mechanic.
Install new spark plugs.
Install new thermostat(s).
Install a new membrane in the fuel pump (rubber).
Install a new fuel filter element.
Check out the fuel line and bulb closely.
Other than having the lower unit checked out, the rest of these steps are not very expensive maintenance items to complete.
Capt Ken
Hmmm, being 1984 was the first year for Yamaha outboards in the states, will probably need better info being this is probably the European model from the numbers
