Re: no foam in boat
The main reason boats over 20' and some I/O's (level floatation)don't require foam is the amount of foam that would be required. On larger boats there would be so much foam needed you'd have to pull a barge full of foam along with you to have enough to float a boat with twin big block engines. It takes a cubic foot of foam to float about 60lbs. To get an idea a 5gal can is less than one cubic foot in volume. So think about finding space for enough 5 gallon cans to float 2000lbs in a small boat. Thats of course after you do all the figuring to find out how much all the different materials displace in water. Then to further complicate everything you need level flotation on some boats and now you can't just put the foam anywhere you want to. IMHO if you are putting flotation in a boat after restoring it and you don't put exately the amount that was originally in it from the manufacturer and in the same places you are just wasting money. If your going to add flotation to a boat without any and you don't do all the calculations for the correct amount and placement you are wasting your money. No matter what you use, noodles, air entrapment, expanding polyurethane, blue sheets, pink, etc. You have to calculate how much you need or its gonna sink anyway (if you have a serious problem). Just throwing flotation at a boat and putting however much you can and where ever you can find room don't cut it.
