I bought a used transom shield and the guys that sold it to me were nice enough to install a new gimbal bearing.
When I was checking the thing out I greased it and the grease came out between the bearing bore in the shield and the OD of the gimbal bearing assembly.
It's supposed to come out between the bearing races where it can grease the balls.
I pulled the gimbal bearing because it thought it was mis-indexed but found a disaster waiting to happen.
The replacement (on the right) didn't have a hole through the aluminum holder, the holder didnt have a circumferential grease groove and the bearing outer race didn't have any grease passages drilled into the ball space.
When you greased this thing the grease had nowhere to go.
This defective bearing says SKF and Mexico.
You don't want one of these in your drive.
