Its a e225txcda can the upper crankshaft bearing be replaced with out breaking the powerhead apart and can I get just the bearing without buying the head and bearing assy. Thank for any input
t
Thanks guys after reading here that the crank has a mynute amount of play mine has a little. would you recommend changing it. Keeper came off timer base an trashed the flywheel and trigger i have every thing off down to the bearing assy.
