Re: winterization of 85 hp force
Lots of stuff on here to pick from if you search, but what i do with the same motor - I also store my boat outside under cover, no heater, and it can get cold up here in the NW.
run the motor till its warm with muffs
run carb cleaner (seafoam etc) to get rid of as much gunk as you can
make sure to run all that cleaner out
I do a two part, I run the motor, pull the gas line to drain all the fluid out of the lines, and kill the water when the motor starts to run out of gas. I am trying to flush all the water out of the motor and all the gas out of the lines at the same time. Just don't run the motor without water for too long.
pull the lower end and drain
While the lower end is off i will re-grease the impeller so its not all cracked and nasty come summer.
while doing other things I usually let the lower end drain overnight so it's nice and dry
replace the lower end and put nice new fresh oil in there.
i pull the thermostat or the little screw at the top and run some anti-freeze down the hole until it drips out the bottom.
a little grease here and there, control arms, shift linkage
wrap the top of the motor in a black garbage bag to keep it nice and clean
pull the plug (nothing worse then a boat full of water when the carport leaks)
put the battery on the tender
I pull all the cuddy cushions and place a box of baking soda in the cuddy
Cover the boat best I can with tarp and plastic.
Start making the list of things to do next summer on the boat.
