How do you remove omc king cobra drive from boat?
brianwells1961 Cadet Joined Feb 16, 2012 Messages 26 Oct 10, 2012 #1 How do you remove omc king cobra drive from boat?
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Oct 10, 2012 #2 Re: how do you remove omc king cobra drive from boat? Disconnect the aft trim rams, remove the 6 retaining nuts holding drive to pivot housing and pull the drive off.
L lake erie monster Cadet Joined Jan 8, 2012 Messages 10 Oct 14, 2012 #3 Re: how do you remove omc king cobra drive from boat? are there any seals or gaskets to replace before reinstalling?
M muc "Retired" Association of Marine Technicians... Joined Jul 7, 2004 Messages 2,334 Oct 15, 2012 #4 Re: how do you remove omc king cobra drive from boat? If it’s a cone clutch king cobra. You need to remove the shift cable pin after the drive has slid back about 1 inch. There is an o-ring that seals the shift cable cavity that some mechanics like to replace.
