79Merc80
- Nov 22, 2007
- 673
Hello:
I have a 1981 Glastron SSV 194 w/ a 228hp, 305 V-8.
The guy I bought it from replaced the upper drive unit with one from a 165hp inline 6. The inline 6 gear ratio is 1.62 and the V-8 ratio is 1.47. I asked and he said he didn't change the gears, so I'm assuming that I am running 1.62 gears in the boat. As it sits, there isn't a "Flat" spot on the throttle where you give it a little throttle and all it does is make a little mor noise (Like going from plowing to planing) It came with a 19 pitch Vengance (I think) prop. I have not yet run it at WOT. I have had it to 4k RPM, buit don't really like to push it that hard. It cruises great at 3k RPM at 31 MPH. Both on plane picturesw are at cruising speed.
The question I have is, how much change is there in the speed / RPM from the gears I have and the gears I should have? The hole shot is very impressive for a 19'er.
Thanks for your imput and advice.
Craig
Craig
