Merc 18 5995557 Kill Switch Wiring
JDusza
My bad.... I didn't note the kill switch wiring before I removed it.
There are two wires coming from the kill switch. One black and yellow. The other black.
The black and yellow goes with black and yellow on the switch box.
Please remind me where the black one goes.
Thanks.
Cheers!
J
M
Maxz695
Guest
Re: Merc 18 5995557 Kill Switch Wiring
The black one should be to ground I believe
JDusza
Yes, it is ground.
do you know which terminal of the switch box is ground?
J
M
Maxz695
Guest
Ground it to the formost upper screw on the switchbox bracket, Philips head screwdriver needed
JDusza
Excellent!
Thank you!
J
M
Maxz695
Guest
your very welcome good luck
