Hey guys,
Newbie, first boat, everything used from the craigslist. Bought this motor with controls off of a boat that they had wrecked. The motor had a bent prop shaft. Bought a used lower unit and put it on. Forward is great, reverse is killing me.
It gradually started grinding reverse worse and worse after 3-5 uses of the reverse. Adjusted the cable without any luck until reverse just completely stopped working. It appeared the used lower unit shift linkage was a little shorter than the original (or maybe not). Moved all of the gears back over to the original lower unit and have the exact same issue.
Reverse locks in when I disconnect the cable but the cable falls half and inch short of pushing it far enough.
Attached are pics.
Will new cables fix this, or is there some other issue??
Attached are pics.
