- Jul 18, 2011
- 19,175
Yea, so I noticed a 'squishy' noise as I walked across the swim platform on my new-to-me Formula 330. Upon further investigation, it seems that the platform is delaminating from its core material (presumably plywood).
So, I did my hammer soundings and drew a pencil outline of the effected areas, which were fairly large as you can see in the images below. So, inside the pencil boundaries the hammer bounces, outside of the area, it is solid.
Access from below is limited to about 3" of space , but visually it looks OK.
The platform does not feel soft or anything like that when I walk on it, but I may as well take care of it now, because it is not going to get any better. . .
Sooo, I wanted to bounce my game plan around here to get any thoughts and ideas before I begin to fix it.
My plan is to make a few pattern samples of the platform texture with some resin. Then drill a few 1" core holes in the effected areas to see if it is wet or dry. Hopefully it will be dry
. . . there does not appear to be any problems with the platform that would let water in, etc.
Then I will probably fill the effected areas with penetrating epoxy via the core holes . . . slap some weight on it and let it set. Then re-glecot the core holes using the texture patterns that I made.
I would add that I had a similar issue with my sailboat , but a much smaller area. I fixed it in a similar way.
T.I.A for your comments and ideas.
