evinrude johnson 25 hp crankshaft swap????
riverhippie
yes i have an 1982 evi mod#e25rcnb its the model that has larger diamiter driveshaft but dosent have the tru pro exaust lower unit. i was just givin a jonson 25e78c my biggest question is can i put the johnsons crank shaft in the evinrude. or are any of the parts on the power exchangeable please help
1946Zephyr
Re: evinrude johnson 25 hp crankshaft swap????
I would go to marineengine.com and look up both engine models, to make sure the cranks both have the same part number. That's the best way to make sure.
durban
Master Chief Petty Officer
it will fit providing its a 1982 model & it will also fit 35hp 1982 , cheers
mark1961
Ensign
Actually, the two crankshafts do have different part numbers but that may only be due to a difference in the driveshaft size/splines......
It would be easier just to source another lower unit imo.
Faztbullet
Sorry but will not fit due to driveshaft splines as posted earlier and only works with the 25 hp motors....
mark1961
Ensign
The OP wants to put a '78 crankshaft in an '82 powerhead so he can use the '78 lower unit.....it would be way easier just to source another lower unit but any chance this would work?
