hitthbricks
- Oct 7, 2012
- 4
I have 1992 Johnson 175 fast strike. It?s mounted on a 1987 Ranger 360 V? I replaced the long block because it was blown.. When I was ready to start the engine the warning buzzer came on and stays on . The engine would not start.. After reading all the posts on this issue I went in and pretty much disconnected every ?Tan? wire I could find to no avail.. On the Johnson control in the boat is where the alarm sound is there is a button that deactivates the alarm.. You push this little button (that is hiding in a horseshoe shroud) and the alarm goes off?ALSO>>>IF I HOLD THIS BUTTON IN THE HORN GOES OFF AND THE MOTOR WILL START !!! Is this strange or a common occurrence?? What am I missing here..Where should I be looking and, NO, I?m not starting it till I get some more info?..
