Re: Need help identifying Mercury motor
Mercury played some games with their mids and lowers during that period. Earlier ones had a full-length shift rod that extended up into the belly pan, while others had a splined coupling below the swivel bracket. Earlier mids also had a shorter "snout" at the rear of the leg where it meets up with the gearcase, with the mating gearcase also have a shorter top surface to match. I believe, but am not 100% certain, the '67 will have the short, and the '73 will have the long. You can tell by looking as the "short" will have the AV plate extending about an inch beyond the rear of top surface the gearcase housing, while the "long" will have the AV plate about flush with the rear of the top surface of the housing. These pics should illustrate what I mean.
