Best Manual, Best place to order parts, Advice on installing new Engine coupler, etc
jvmorris
Good Morning, New boater from Moore Ok. I have a 1994 OMC with
4.3 vortec Mdl # 432ACPMDA serial # T01268666
Cobra Outdrive Mdl # 3868076 serial # T0781530
To make a long story short, rookie boater hit a submerged sandbar and broke some things.
After talking to two local repair shops, I decided to get to personally acquainted with my boat.
I have some questions that I am sure have been answered but I could not find them.
1. What are the best detailed service manuals for this Motor and Outdrive?
2. Where is the best place to order parts?
3. Since I am replacing the engine coupler and this is a new boat to me, should I go ahead and replace the gimbal bearing, u-joints and boots also?
Thanks for your time and your help
Jeremy
halfmoa
Ensign
Re: Best Manual, Best place to order parts, Advice on installing new Engine coupler,
1. OEM
2. iBoats.com is pretty awesome. Good customer service. They've also got a free forum that's very helpful. :rolleyes:
3. I would
southkogs
Welcome aboard Jeremy:
"Factory manual is the best, then the Seloc. Clymer if you're desperate." - Howard Sterndrive
Start HERE. iBoats will have quite a bit too.
Are you getting any leaking? Any clue as to how long it's been since they've been changed? I'm not sure what the regular schedule is for changing them (someone else will chime in), but it never hurts to do them if you're already taking it all apart.
Don S
Bellows should be replaced if you don't know the age. If the gimbal bearing is smooth and well lubed (Not rusty) no reason to replace it. Same with the ujoints. You can probably just grease them through the zirks (if they have them) and be good. Bellows are a preventive maintenance thing like the impeller. Steel bearings are not. You don't just replace all the bearings in your outdrive because you don't know how old they are.
jvmorris
Thanks for all of your help guys! Hopefully I will start going back together with it. Next week when the parts are in.
Again thanks for your time cant wait to get started.
any advice on this process is welcomed.
Jeremy
Jeremy
Ayuh,.... Welcome Aboard,.... What, got broken, other than the coupler,..??
Is the hull leakin',..??
Bein' a '94, if the motor is original, it's Vortec in name only,... Vortec heads were intro'ed in '96...
'n, while the motor is out, Closely inspect the transom for Rotten Wood,...
Not knowin' it's care since '94, it's a candidate for it...
projo198
I'm a fan of wholesalemarine.com, lightening fast shipping (which is good if you want to be on the water by the weekend lol)...
