I recently purchased a 1998 Johnson 8HP J8FRECA 4 stroke and was told that water was entering the top cylinder due to a cracked engine block. As recommended, had a used block with new gaskets installed, but continue to have the same problem. It is now recommended that I send the head out to be magnafluxed. Wondering if there are any other issues that could cause water in the top cylinder besides a cracked or warped head. Thanks for any suggestions.
