mikefunaro
- Oct 2, 2012
- 1
Hi Everyone,
I'm new hear. As my dad gets older the maintenance and and upkeep of an early 2000s Bayliner 2050 capri has fallen to me.
In the past we've been somewhat diligent with washing the exterior. The boat is in freshwater and an aluminum lift that keeps most of the boat above the water so bottom scum etc is not a big problem. We have applied wax at most once or twice over the last few years and the exterior is starting to look a bit jaded.
So a few questions. I've searched around the internet a bit and haven't found too much information and would like to get some opinions and individual care regimens. I also looked to bayliner but their instructions are pretty vague.
1. What's your pick for an overall cleanser? What about wax??
2. The bayliner blue stripe area around the boat has become rather faded in some areas. It's to the point that if you wet it, however, it kinda comes back to life. Is this sort of fading possible to eliminate with wax or do I need to gel coat over everything?
3. What's the difference between a gel coat and a patch paste? Is a gel coat colored?
4. What's the difference between buying gel coat and applying additional gel coat versus cutting down the existing gel coat with compound? Is buying gel coat only for patch areas?
If there's a good reference to this that someone can link me to I'll gladly read it. Not trying to be lazy just trying to understand all of this.
Thanks
Mike
Thanks
Mike
