The Stern drive on our Mercruiser 3.0L was leaking oil, so we drained the oil and removed the Stern Drive. The upper and lower units were separated. The oil seals in the shift shaft assembly were leaking badly and a new assembly was ordered and installed. The shift shaft was turned clockwise as viewed from the top while turning the prop counterclockwise until it locked. I held the shift shaft in the forward position while a friend lowered the upper drive onto the lower drive. The prop was turned counterclockwise slightly to align the splines and the upper drive seated nicely. While still holding the shift shaft, bolts and nuts were tightened securing the upper and lower unit. While still holding the shift shaft my friend turned the prop counterclockwise to ensure the drive was still is forward. When the prop was turned clockwise a clicking sound could be heard. The stern drive was then mounted, but the prop is locked in forward regardless of the shifter being in forward, neutral or reverse. Also when the prop was turned clockwise there was a faint click, but nothing like it was when the drive was not mounted. We tried this three times and resulted in the same results. I have referenced the service manual for the drive and somewhat mechanically inclined, but have exhausted options and probably missing something.
Any assistance would be greatly appreciated.
Thanks
Tim
Thanks
Tim
