Silverhammer
- Mar 12, 2012
- 6
Hi Guys,
Im working on a 1985 force 50. I received it with a broken tower shaft and sheared key. My assumption was that the towershaft broke and knocked it out of time,causing backfire and shearing the flywheel key. I replaced the towershaft and key, fired it up and at an idle, it backfired and sheared another key. I am suspecting that the pressed-in sleeve in the flywheel may have spun. Am I correct in assuming that when no.1 is at top dead, the timing mark on the flywheel should be aligned with the timing marks on the tab mounted on the head? Also, I've read in this forum that the points should be set at .020. However, my manual states that they should be at .015. Also, if the flywheel is spun, what years and models of flywheels would interchange on this one?
Thanx,
Silverhammer
Thanx,
Silverhammer
