Does anyone have experience using the ESI DVA adapter? Does it read accurately on both sides of the power pack? Can you use it with a digital meter, or only analog. I thought it was either, but I see the one that ESI sells is analog, so I'm not sure. Do you keep it set in DC volts no matter what you are testing on the engine?
Thanks!
Thanks!
