Sorry for the long thread, but I would like to get advice on winterizing/storing my pontoon.
I bought a 26' Suntracker Tri-Toon with 150hp Mercury 4-Stroke last spring. This will be the first "winter" for it here in Illinois.
I have a floating 5000lb pontoon lift. Air goes in to pump the water out of the floats to raise the lift, and water goes back in the floats dispersing the air to lift the pontoon.
I was told that I could have a service tech come out and "winterize" the boat on the lift in the dock, or they could come and trailer it to their facility, but it would have to be shrunk wrapped and stored "outside" (details later)
My questions are:
1) I understand that I should have my gas tank at 3/4 full before he adds the stabilizer, and that I should keep the engine trimmed in the down position? Do I need to take the battery out?, if so I will have to have them do it. I guess if I don't it will just need to be charged in the spring, or can it be damaged from freezing?
2) I was originally wanted to store it off lift "inside", but was told by tech that since I did not have a trailer for it. (Didn't buy one, because I don't plan on going to any other lake), that they could store it but it would have to be shrink wrapped and stored outside, as a trailer is necessary to store it "inside".
After hearing that, my thoughts are now to leave it on the lift over the winter, since it is covered somewhat from the elements and have the engine winterized on the lift. It didn't seem right to leave it out all winter in the middle of a concrete cornfield.
Should I have it shrink wrapped on the lift then, or just leave the "snap" custom canvas cover on that I bought for it. The canvas cover I has snaps every 8-inches all around the boat, and has a couple of posts to keep it from sagging as well as vented. Shrink wrapping would cover all the way down the sides under the deck though. The canvas seemed to keep everything dry, but for a few spiders etc. getting in, but we have been in drought conditions all summer here.
Also, it is OK to leave the outboard "uncovered", even though it will be somewhat protected some by the dock roof, or is there something I should cover it with.
The dock guy said I should get a bubbler for the dock to keep the ice at bay just in case either way, although last winter the lake didn't even freeze much by the shore. (Mild winter)
Any other suggestions/alternatives, or comments on what I am doing? Thanks in advance.
My questions are:
