beckoning
- Dec 15, 2010
- 177
OK. Thanks to some iBoats responses about 2-stroke vs 4-stroke kickers. I am narrowing my replacement kicker search (mounts on stern, no bracket) with the focus on weight, same fuel as main which is 2-stroke with oil resevoir and internal pump, and long shaft. Since I live in a somewhat remote area, I want to stay with the most reliable brands and those my local mechanics understand. That leaves a few questions on which I hope to get as many opinions as I can: 1) Is there a recent vintage 8-9hp 2-stroke (prefer Mercury or Yamaha, but Evinrude/Johnson would do too) with an internal pump and oil tank so I don't need to use pre-mix? I cannnot find anything on their sites, so to avoid pre-mix, I may need to go 4-stroke. 2) Among Mercury, Yamaha, and Honda, which is the lightest long shaft 9.9 hp 4-stroke? I looked at 2012 specs, and Yamaha seems lowest weight, but maybe older models are different. 3) Do the Merc, Yamaha, and Honda 9.9hp 4-stroke motors all have about the same reliability, long life, and simple maintenance? I've had 2 large Mercury motors that just won't quit, and the local mechanics can easily repair, and I've heard good things about Yamaha. And my current 4hp Evinrude kicker (pre-mix) is very reliable. My inclination is Mercury or Yamaha, but I want opinions of as many others as I can get.
Thank you in advance for all your opinions and advice.
