Re: pourable or 2in foam board
Don't forget pool noodles and Tide jugs, good, bad or indifferent, that's what I've got under mine. I do have a bouncy spot where the one span between crossmembers was 2 feet. I'm going to change out the bottom deck carpet for a piece of vinyl over the winter. I'm just about certain I will cut some 3 inch holes and pour a bit of 2 part foam on each side to try to firm the deck up right there while I have the carpet up.
If you use only noodles or foam board consider the lack of support that you'll have after. My boat came from the factory with 1/2 in decks that were quite solid with the poured foam right up against them, but the 1/2 decks in it now are just a little bouncy without the foam support. The only place it is real noticeable is in the 2 foot gap in the crossmembers.
Although it doesn't bother me my boat is noticeably louder without the foam under the deck also.
